Need some help
Old Oct 18, 2014 | 12:10 PM
subford's Avatar
subford
Originally Posted by EddieBauer95'
Ok, so after the KOEO, it gives me the codes, then your saying there is a single flash, pause, then the memory codes?
That is also true.
Old Oct 18, 2014 | 12:19 PM
EddieBauer95''s Avatar
EddieBauer95'
Ok great, thanks! Guess I will have to take it for a cruise today- hopefully it acts up as it seems to be hit and miss when it does.
Old Oct 18, 2014 | 12:49 PM
EddieBauer95'
Ok so that worked out! Took it for a drive, and it acted up again. So went home and pulled codes, I got 628 KOEO (CM), and 111 KOER.
Old Oct 18, 2014 | 01:43 PM
EddieBauer95'
so would it just be the TC solenoid or the TC itself? Any ideas? Would a bad TCC solenoid cause the shuddering/engine trying to stall/whining noise/hard 1-2 shifts, or is the TC completely toast? I talked to the guy that works at the NAPA in town (used to be a mechanic), and he said hes mostly dealt with the solenoid failing, rarely ever the converter itself.
Old Oct 18, 2014 | 06:06 PM
dixie460's Avatar
dixie460
Originally Posted by subford
CM = Computer Memory.
Actually it's Continuous Memory.
Another one of those strange names Ford comes up with, right up there with Profile Ignition Pickup (PIP) and Differential Pressure Feedback, Exhaust (DPFE)!!
OP, do the symptoms go away when lightly touching the brake pedal? Try it out... hold your speed steady with one foot and just barely push the brake pedal with the other. All you want is to activate the brake lights, which also signals the computer to disengage the converter clutch.
Old Oct 21, 2014 | 11:14 PM
EddieBauer95'
Sorry, my internet has been down- yes, the symptoms seem to go away when going at a constant speed and then toughing the brake
Old Oct 22, 2014 | 07:24 AM
subford's Avatar
subford
The term continuous memory was coined by Hewlett-Packard (HP) in 1976 to describe a unique feature of certain HP calculators whereby the calculator could internally sustain most, or in later models - all, of the contents of user memory (via battery-backed CMOS memory).
Fords definition of Continuous Memory:
Continuous Memory: The portion of KAM used to store DTCs generated during Continuous Self-Test.
Continuous Self-Test: A continuous test of the EEC system conducted by the PCM whenever the vehicle is operating.
Keep Alive Memory (KAM): A portion of the memory within the PCM that must maintain power even when the vehicle is not operating.
I know that the Ford manuals call it Continuous Memory but that does not describe what it is. If you remove the battery cables the codes are lost so that does not fit definition of Continuous Memory to me. The PCM computer does not have a little battery to keep the memory.
Ford should have called it KAM and not CM.
Besides the novice better understands it if you call it computer memory.
Old Oct 22, 2014 | 01:27 PM
EddieBauer95'
So since the shuddering goes away when the brakes are touched, does that mean the TC is still good? Could it be the solenoid? Could a bad VSS be causing these issues? My CEL does not come on at all though.
jovialwoodchuck
Aug 1, 2018 02:08 PM
Paul T
Aug 25, 2014 08:33 PM
Schiz
1997 - 2003 F150
Jul 27, 2013 12:08 PM
809taino
Feb 5, 2013 07:52 AM
CowboyBoots
Sep 9, 2010 10:28 AM
