Leaky Situation
Old Oct 17, 2014 | 03:34 PM
Smokey_7.3's Avatar
Smokey_7.3
Leaky Situation
Hey everyone! Well after I tackling the bent connecting rod problem, I'm onto the next. 😧
I have a fuel leak in the valley that isn't coming from the FPR, Fuel bowl, or the rubber lines. It's kinda of a trickle; I can catch 1/2 a gallon in a pan in 7 min under the truck when I'm idling. Worse when rolling obviously. All dripping down behind the block, passenger side.
In the valley, before and under the banjo bolts seems to collect the most but I'm unsure of where it's coming from. All of that is tightened. The fuel bowl has all new o-rings and the bottom of it wasn't pitted badly.
I welcome and appreciate any and all help.
Old Oct 17, 2014 | 06:09 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
There is a weep hole on the fuel pump. Could be there.
Old Oct 17, 2014 | 07:43 PM
DIYMechanic's Avatar
DIYMechanic
^^What he said^^
That would be my guess as well. You can see it with a mirror and a light if you're willing to deal with the frustrations of doing so. If not, dry thing out as well as you can, stuff dry rags in everywhere, start the truck briefly and see which rags get wet first. Anything that leaks in the valley will drain where you're describing so it could be coming from just about anything in there, but I'm still guessing fuel pump.
Old Oct 17, 2014 | 07:57 PM
fordman67's Avatar
fordman67
Rear fuel line seals at the head!
Old Oct 17, 2014 | 08:42 PM
MOOSE_MACHINE
Or there. The orings that go in those fittings at kind of a square oring. Like a cut piece of hose.
Old Oct 17, 2014 | 11:27 PM
fordman67's Avatar
fordman67
Yep! They erode from the fuel pump pulsses IMO.
Fun to replace too
Old Oct 18, 2014 | 11:31 AM
Smokey_7.3's Avatar
Smokey_7.3
I'll check around the pump more later this weekend. But as far as everything else around it, nothing leaks. I might have developed a tear in the lines somehow I don't know. I'll definitely replace all the hoses while I'm replacing the pump.
Thanks yall
Old Nov 25, 2014 | 04:57 PM
Asytole61's Avatar
Asytole61
leak?
Thanks yall
Just a thought, had a simular fuel leakage problem last year Had to replace the whole fuel cylinder housing seems there was corrosion from the bottom of housing do you heating element in bottom of bowl causing this corrosion through electrical charge/and water
that settles in bottom and not purged after a while.
Changed whole bowl assembly and replaced fuel pump underneath.
Old Nov 26, 2014 | 06:55 AM
96_Powerstroke's Avatar
96_Powerstroke
I had the same thing going on, replaced my lift pump. Problem solved.
Old Nov 28, 2014 | 08:31 PM
dailejc's Avatar
dailejc
Just finished replacing my fuel pump (along with glow plugs and injector orings) today. Mine was leaking from the weep hole as well. Hard to tell, had to really clean it up good to see where it was leaking from. Good time to rebuild fuel bowl too. And I didnt remove the turbo, easy enough to do it without doing that in my opinion.
schlepprock250
May 20, 2013 08:21 AM
DR JOE
27
Jul 2, 2011 09:31 AM
clbostian
Oct 10, 2010 11:09 AM
weekendwarriorfsw32
17
Jan 16, 2009 08:02 PM
meccox
Jun 12, 2007 08:42 AM
