Fitting SS Brake Lines
Old Oct 17, 2014 | 11:07 AM
kuneefay's Avatar
kuneefay
So recently I've been having my front passenger side brake caliper sticking on my 2000 v10 limited. Consequently my pads on that one side have uneven wear with the drivers and I will be swapping both calipers out with remand units, ebc yellow stuff pads and potentially new stainless steel braded brake lines. My rig came with a lift when I bought it and I was told that it was only a 2" lift but the guy didn't seem positive . How would I measure for the amount of lift in order to determine if I should go with stock length lines or the extended lines? Thanks for your guys' time.
Old Oct 17, 2014 | 11:26 AM
WE3ZS's Avatar
WE3ZS
To take tire size out of the mix, measure from the top center of the fenderwell lip to the center of the hub. Then we can compare it to other's measurements to determine the total over stock lift.
This thread should help some,
https://www.ford-trucks.com/forums/1...easurents.html
Old Oct 17, 2014 | 11:30 AM
kuneefay's Avatar
kuneefay
Great Ill do that when I get home. The tires are 35's btw.
Old Oct 17, 2014 | 02:06 PM
mecdac's Avatar
mecdac
These fit up to 5" lift http://www.summitracing.com/parts/ru...odel/excursion
Others available.
Old Oct 17, 2014 | 04:34 PM
stpete's Avatar
stpete
Others available.
The Russell website claims those are for 6-8" lift.
BTW, anyone know where to get SS lines for a 2WD?
kwissman
Apr 24, 2009 04:07 PM
zstyle01
Apr 2, 2007 11:59 PM
Ford4x4CountryBoy
Feb 18, 2005 05:32 PM
Fordnite302
Mar 11, 2003 01:40 PM
99ebexpy
Jan 30, 2003 08:25 PM
