Sponsored by: Kumho
Brake lines
Old Feb 18, 2005 | 11:50 AM
Ford4x4CountryBoy's Avatar
Ford4x4CountryBoy
Brake lines
I'm putting a 4" lift in my 1994 f-150 and was wondering if i'm gona need to extend the brake likes or reroute them somehow...and was wondering if i got the same brakelines from the same yera of pickup if i could just attach them as extensions..thanx
Old Feb 18, 2005 | 05:32 PM
mattd17's Avatar
mattd17
you shouldn't need to do anything with a 4" lift. when you put it on, then you may have to alter the bracket just a little, some people just turn them upside down and bend the hard tubing. usually the brake lines will be good up even on a 6" lift, but it is always a good idea just check how much play you have if you get a lot of flex in it. goodluck !!!
