I need a master tech opinion!
Old Oct 16, 2014 | 08:27 PM
Restlesswildman's Avatar
Restlesswildman
Short version is I had a replacement hitch put on the truck. Truck never leaked fuel in the 2 yrs I had it. It now leaks.
Climbed under it tonight looking for a hose leak. Turns out that the tube extension is leaking where it mates with the tank.
Is there a fix for this other then replacing the tank?
Old Oct 17, 2014 | 02:43 AM
Yahiko's Avatar
Yahiko
I take it you have a poly tank.
I don't know if the Ex is listed on the DVDs I have.
I'll look and if I can post a breakdown or what ever they have.
Sean
Old Oct 17, 2014 | 03:00 AM
Skip1970's Avatar
Skip1970
our ex has a poly tank.
Old Oct 17, 2014 | 03:44 AM
Yahiko's Avatar
Yahiko
No Love The DVDs don't say. They don't
even get into the venting with the diesels
like they do on the gas ones.
I even tried to pull a diagram up on line
of the tank and components and still no love.
Sean
Old Oct 17, 2014 | 05:40 AM
David7.3's Avatar
David7.3
Is it wear the fuel fill hose attaches to the tank? Is it anywere they were working on the hitch? I had a leak in that area everytime I filled up, replace the filler with one from rock auto and the problem was solved. Poly tanks are pretty tough, were the fuel pump module goes in the tank there is a trough that leads to that side of the tank, could it be running down from there? Does it leak all the time, or only when running?
Old Oct 17, 2014 | 09:48 PM
Restlesswildman
I talked to a guy I bowl with that is a Ford tech tonight. I showed him the picture I took. He told me that it will require a tank replacement since it is the tube extension that is welded to the tank. The large filler hose attaches to it.
The insurance adjuster called my wife back today and they are going to setup the repair for us. The adjuster finally looked up what was involved to replace the hitch on the excursion. The body shop and the hitch/trailer dealer that did the work said that they did not touch the tank at all. That is against what the adjuster found out.
Old Oct 18, 2014 | 03:01 AM
Yahiko's Avatar
Yahiko
Sounds like they did and just don't want to pay for it. i got a look at prices
on that tank. OUCH! What about a tank from >> https://titanfueltanks.com/
I don't know if they have one for you rig or not.
Sean
Old Oct 18, 2014 | 09:35 AM
Restlesswildman
Yahiko the quote I got from Ford direct parts. com was 2890.00 plus shipping!
MuddyAxles
Jan 26, 2018 03:23 PM
Yahiko
Sep 19, 2016 03:57 PM
ElvisLives01
Jul 21, 2016 05:10 PM
DumbLuck
Sep 14, 2011 02:47 PM
quinb
1997 - 2003 F150
Feb 1, 2008 01:27 PM
