fuel issues
Old Oct 16, 2014 | 08:01 PM
James_24_85's Avatar
James_24_85
fuel issues
I just became the new owner of an 89 f150 302 4x4 4 speed and I've got some fuel issues. Truck will idle fine them all of sudden jump up to 2 ggrand and stay there sometimes revving makes it go back down and sometimes it wont also sometimes iit kinda has a rough idle and sometimes it has a hard time starting. And sometimes even after its been running for an hour or so and is warmed up it will not start back. I've been told this was not the factory engine and wonder if someone pulled a motor from an automatic would cause computerm issues any input would be appreciated. Good to be back on this site I've been away for a while.
Old Oct 17, 2014 | 09:09 AM
James_24_85
Any thoughts. Somebody has got to have an idea
Old Oct 17, 2014 | 09:52 AM
rla2005's Avatar
rla2005
The engine idle speed is controlled by the computer (PCM). Anytime there is an issue with computer controlled functions you should follow these very common instructions: Check for Codes! Run the KOEO tests and CM display.
Run the tests and code display, list them here, by number, and when they were displayed. Do not reply back with "no codes". At the very least you will get the System Pass code of 11 (repeated) for KOEO and once again for CM display if there are no stored codes.
Old Oct 17, 2014 | 06:33 PM
James_24_85
Ok I just researched how to do that and I'll do it tonight or tomorrow I'll do the koer also. Thanks so far
Old Oct 19, 2014 | 12:16 AM
James_24_85
Did the koeo and if I'm reading it right I got an 81 41 and 33. Can't do the koer right now as it would wake my daughter. But I got 8 flashes then 1,
8 then 1 long pause 4,1, 3,3 then repeated 4,1,3,3.
Old Oct 19, 2014 | 09:04 AM
rla2005's Avatar
rla2005
Code 81 (KOEO): Air Management 2 (AM2) circuit failure
Is the air injection control solenoid still hooked up electrically? Not sure if it is the TAB or TAD solenoid.
Code 41 (CM): No HEGO switching detected (System Lean)
Code 33 (CM): EGR valve opening not detected
A lean condition can be caused by a vacuum leak. A vacuum leak can trigger a high idle. Yours is intermittent so it may be tough to track it down.
Old Oct 19, 2014 | 08:50 PM
James_24_85
Ok thanks I will check those connections tomorrow
Old Oct 20, 2014 | 07:06 PM
James_24_85
The tad was not hooked up. Not sure if someine unplugged on purpose but the retaining clip was broke off
Old Oct 20, 2014 | 07:19 PM
rla2005's Avatar
rla2005
Good find!
Old Oct 20, 2014 | 07:29 PM
James_24_85
Just did the koer and got codes 41. 33. 25. 52. This was after I plugged the tad back up
Old Oct 20, 2014 | 07:50 PM
rla2005's Avatar
rla2005
Code 25 (KOER): Knock not sensed during dynamic test.
Perhaps you did not goose the throttle enough?
Code 33 (KOER): EGR valve opening not detected.
Is the vacuum source and EGR Valve Regulator (EVR) intact?
Code 41 (KOER): No HEGO switching detected always lean.
You need to start tracing down that pesky vacuum leak...
Code 52 (KOER): Power steering pressure switch always open or closed.
There is a sensor on the power steering box, is it still connected?
Old Oct 20, 2014 | 10:21 PM
James_24_85
I didn't turn the steering wheel b4 diagnostics began. There is a little round cannister on top of the ugly coffee can looking canis terrible on the passenger siside it has a large hosE coming off of it towards the passenger side couldn't tell what it was. But anyway that hose was just sittin loose on there is it suppose to be that way? I'm gonna try to pick up a hose clamp for it tomorrow. Thanks for the help this far.
Old Oct 21, 2014 | 07:58 AM
rla2005's Avatar
rla2005
The metal coffee can is a vacuum reservoir...that is well known to rust out on the bottom.
The other device you describe is probably the air pump silencer/filter.
rj1983
Jan 5, 2018 05:59 AM
overhaulin
Aug 15, 2014 01:16 PM
ralbach
13
Oct 13, 2012 10:26 AM
5.0 Fordota
Jul 1, 2009 05:41 PM
ATVBronco
Bronco II
23
May 5, 2006 01:34 PM
