Eye Candy Upgrades
Old Oct 16, 2014 | 01:50 PM
dalspot's Avatar
dalspot
Old Oct 16, 2014 | 02:30 PM
BigBlueOx's Avatar
BigBlueOx
Originally Posted by dalspot
Is there an easy way to get the vents out?
Pop the headlight switch out (just snaps in) and you can get to the clips on the back with a little patience the vent will pop out.
Old Oct 16, 2014 | 03:04 PM
dalspot's Avatar
dalspot
Thanks Steve, what about the other 3?
Old Oct 16, 2014 | 03:14 PM
BigBlueOx's Avatar
BigBlueOx
On the center ones. Pop the left and right lower panels out. Remove screws in corners. (Marked with red arrows)
Take those screws out and you can pop the whole center radio surround off and get those ones easy.
Old Oct 16, 2014 | 03:19 PM
BigBlueOx's Avatar
BigBlueOx
Bare with me I'm having issues posting more than one pic at a time from mobile.
This is what they look like when they are removed. To give you an idea of what they look like from behind. And what holds them in (clips marked with red circles)
And the other clips not marked, hold the vent itself together. You may want to completely disassemble to paint.
Old Oct 16, 2014 | 03:43 PM
BigBlueOx's Avatar
BigBlueOx
Another hint. When putting them back in, line each of the 4 clips on vent with the clips on the four corners. NOT top, bottom, left, right.
You'll know if you get it wrong because if you pull on the vent after you reinstall it. The vent will wiggle in the dash.
Old Oct 16, 2014 | 04:04 PM
BigBlueOx's Avatar
BigBlueOx
And for the right side dash vent. It needs to be pried out from the front. I used a screwdriver (junkyard dash) but I have plastic pry bars that I will use on my truck.
You'll need to work your way all the way around with your pry bar on this one.
Old Oct 17, 2014 | 10:45 AM
antwan181's Avatar
antwan181
@dalspot I see those VF plates... you need some lights on there brother!
Old Oct 18, 2014 | 03:56 PM
Tofan's Avatar
Tofan
I have a thread on here that shows how to take the whole dash apart. You don't need to take out the headlight switch. You can also order the black vent pieces. I found a guy on here and switched him everything in the truck that I could
Old Oct 19, 2014 | 09:04 PM
BigBlueOx's Avatar
BigBlueOx
It takes 3 seconds to take out the headlight switch. Why would you take the whole dash apart? Can you get all four at once that way?
Could you post the link?
I got mine out of a junkyard truck and I'm still waiting for my ordered truck to come in. I know how to swap them out but I'm always up for a better/faster way to do it when I get my truck.
I was also going to take the vents apart and use the matte black outer rings from the black vents and use the silver inner louver from the chrome vents.
I'll at least try it to see how it looks.
Arnold Kenyon
May 7, 2017 09:41 AM
51fordf5
19
Jan 5, 2014 08:41 PM
drewpyd85
Mar 21, 2013 09:31 AM
MIKES 68 F100
Apr 8, 2012 08:17 PM
oem78
Feb 14, 2010 10:52 AM
