Brake lights not working
Old Oct 14, 2014 | 06:46 PM
beemr's Avatar
beemr
I know this isn't the right forum, but I have been with you guys for years, and everyone seems to know the right answers and will reply back promptly. The guys here seem more knowledgeable than the ordinary truck guy.
I'm trying to fix the brake lights on a 1998 F150. They will not come on.
The turn signals work, the flashers work, and the running lights (head lights) work. I checked the bulbs and both filaments light up during the above processes.
I removed the brake switch at the pedal. I checked it by hand, and then put a new one on and checked it. No luck. When I was removing it, I heard some clicking under the dash. I connected the 2 pins with a wire (bypassing the switch), and got a spark a few times along with the clicking sound like a relay,and the brake lights would come on, but now nothing. No sparks, no clicking. The flashers and turn signals and running lights still work.
There are no blown fuses in the fuse box to the left of the steering column.
Is there a relay somewhere under the dash just for the brake lights?
Any clues?
Old Oct 15, 2014 | 04:29 AM
Yahiko's Avatar
Yahiko
FTE Remembers
I would say if you want to bring it over we can check it here.
But I see that your more than a short hop away.
Have you checked to see if you have any power at the switch?
The fact that is was lighting and now is not at all makes me thing
you going to go in a bit deeper. Can you get you hands on a basic
wiring diagram. Even a Chiltons would be of some help at this point.
The best one would be a Ford diagram. You can also get one at
Motorcraft Technical Resource
Or
ALLDATA - OEM Auto Repair Information for Professionals
Then there are Free things like your local Library Reference Section
or the WWW
Here are some I found
Trailor Lights - F150online Forums
I found this one here on FTE
Be sure to thank Ctubutis Jump over and give him some Reps for that nice post.
https://www.ford-trucks.com/forums/1...ml#post9993974
Sean
bykr
Jul 14, 2016 09:55 AM
Hoagland
Aug 21, 2012 09:41 AM
Raykey
1997 - 2003 F150
Jul 28, 2008 06:40 PM
ctvanover
Feb 19, 2007 09:04 PM
knee_scraper
Oct 14, 2004 10:29 PM
