1966 352 tear down
Old Oct 13, 2014 | 05:40 PM
AboutTime's Avatar
AboutTime
Trailering
1966 352 tear down
I have my 352 almost completely dismantled. However I have two stubborn issues.
1. Main bearing caps 3 and rear cap do not want to come free. any hints on removal?
2. Camshaft does not want to come out, any hints on removal? I read in Steve Christ's Big Block book that waiting until pistons and crank are out may help (better access). I have also put the gear back on and tried rotating it but no luck. Any other thoughts?
Thanks in advance!
Old Oct 13, 2014 | 05:42 PM
85e150's Avatar
85e150
For main caps, a big soft faced hammer.
Cam--pulled them lifters, right?
You may have to get in there from the bottom side and look for whatever is holding it up, maybe part of a bearing shell or other debris.
Old Oct 13, 2014 | 06:27 PM
Oldschool2888's Avatar
Oldschool2888
Cam
When you turn the up side down watch out for a lifter stuck in the lifter bore may have been the cause all along for cam not moving
Old Oct 13, 2014 | 07:15 PM
tbm3fan's Avatar
tbm3fan
Well if there are no lifters left in then you could use a long hefty screw driver and slip it down one of the holes in the intake valley and leverage against a cam lobe. That's is what I needed to do 6 weeks ago.
Main caps soft mallet and tap each side.
Old Oct 13, 2014 | 09:25 PM
AboutTime's Avatar
AboutTime
Trailering
Regarding the cam, lifters are out. I will try the screwdriver method.
For the caps I use the rubber mallet for all the other caps but #3 does not want to come out. The mallet will not work for the rear cap. It is held in by a "key" that is part of the block on each side. The cap will have to be lifted straight up. Any other thoughts?
Old Oct 14, 2014 | 07:54 AM
69supercj's Avatar
69supercj
Put a couple caps back on then tap down on the snout and the rear flywheel flange and try to knock the cap free that way?
Old Oct 14, 2014 | 08:46 AM
bertha66's Avatar
bertha66
Put your bolts back in the bolt holes and hold them up about 1/2 way down the bore; hold them up and toward the middle of the cap and use them for a handle. Move them back and forth while pulling up at the same time. This will also work on the rear cap; the "key" looking thing on the side is part of the rear main seal set-up.
Old 4x4
Jul 13, 2009 10:03 PM
Franken-Truck
Oct 4, 2007 05:43 PM
superskip
Jun 27, 2005 09:59 AM
dada
Apr 16, 2004 04:03 PM
mlf72f250
Jun 20, 2003 11:04 PM
