starting issues
Old Oct 13, 2014 | 10:50 PM
FOXB22's Avatar
FOXB22
2nd Gear
starting issues
I am new to this forum and I am not sure if this has been covered but ill ask anyway. I have a 1965 ford f100 style side that was originally bought by my grandfather in 65. I have had it out in Western WA for about 2 years now and starting this summer I have had a few minor issues with it. First and biggest is that once the engine is warm 190-200 degrees and I park it for about 35 to 45 minutes it won't want to start back up again and it takes several cranks to get it to fire back up if it does fire back up sometimes it just doesn't fire up again until completely cold again. I have done a bunch of reasons for this but to me its almost like its flooding after I turn it off.
Thanks for any input
also any one know any fast and easy ways to calibrate a gas gauge I fill the tank up and my tank gauge will say empty and when I fill it back up it only needs around 8 gallons before its full again.
Old Oct 14, 2014 | 01:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by FOXB22
Also anyone know any fast and easy ways to calibrate a gas gauge?
I fill the tank up and my tank gauge will say empty and when I fill it back up, it only needs around 8 gallons before it's full again.
Welcome to FTE
Remove the sending unit from the tank, take the float off the arm and shake it to find out if there's gas sloshing around inside.
The float is made from two pieces of copper soldered together. Solder breaks down, gas seeps in, float settles towards the bottom of the tank.
The float (COAZ-9202-B) is still available from Ford, it can be bought at a discount from FTE sponsor horizonpartsguy.com (Horizon Ford - Seattle WA), but...
Carpenter (dennis-carpenter.com) sells a one piece brass float that'll never leak for around 5 bucks.
Old Oct 14, 2014 | 08:10 AM
Ozarktraveler's Avatar
Ozarktraveler
Heat-soak. Try a carb spacer.
Old Oct 14, 2014 | 09:43 AM
sseebart's Avatar
sseebart
Sounds like heat soak to me, too. Before you try the spacer, though, make sure that the fuel line is not touching the manifold, your pump is in good shape and the lines, filters, etc are clear. Sometime poor fuel flow can turn minor heat soak into a major issue like yours.
~Steve
67 StylesLide
Jul 28, 2019 09:56 AM
nhill2090
Nov 12, 2007 07:19 PM
moiamiervous
Mar 11, 2004 08:42 PM
heavy_56
Aug 27, 2003 11:23 PM
78bigunns
Sep 11, 2002 08:10 PM
