53-56 frame differences?
I have never had two frames side by side to compare but I found a 54 (canadian,had a flathead) 3/4 ton frame and would like to know what is different as far as cross members etc.What is involved in putting a yblock in the frame.Just the front cross member?
Thanks Dave
Thanks Dave
Are you looking for a long bed frame? Most of the F250 3/4 ton trucks I have seen have an 8 ft bed. In the F100 line the biggest differences between the slant cab and the 56 is the length of the rear springs, the battery tray, and the running board brackets. The I6 had a different front engine mount crossmember than the V8 but I am not sure how that may have changed between the years.
I can purchase a 54 mercury 3/4 ton frame that had a flathead.The frame for dad's 56 m 100 was a factory long box with a y block.It has front end damage and an this would be an easier route to go.
crs22
20
Aug 8, 2014 12:32 PM
fiftysixfordf250
31
Jun 14, 2013 07:23 AM
halfdone
May 26, 2005 12:08 AM
