power window fuse
Old Jun 10, 2011 | 05:26 PM
jbain's Avatar
jbain
Question power window fuse
i have a 02 mountaineer and the fuse keeps popping for the power windows and my radio. i took it to the ford dealer and paid for them to diag it once they said it was just a fuse and replaced it but its happening every 2-3days after i replace the fuse. is this a common problem or where should i start looking myself
Old Jun 10, 2011 | 09:06 PM
shorod's Avatar
shorod
Which fuse is blowing? The 2002 Mountaineer power windows use a 30 amp circuit breaker, and that 30 amp breaker gets power from a 60 amp fuse in the battery junction box. Are you blowing the 60 amp fuse? The GEM module controls the Accessory Delay Relay which will power the radio and the power windows when the key is On as well as after the key is turned off until a door is open or the exit delay times out. The relay coil is powered by 15-amp fuse F2.17 in the Central Junction Box. Is this fuse the one that's blowing?
-Rod
Old Jun 11, 2011 | 06:28 AM
jbain's Avatar
jbain
its the 15amp fuse
Old Jun 11, 2011 | 10:17 AM
shorod's Avatar
shorod
Fuse F2.17 feeds a whole lot of stuff. First up are the Accessory Delay Relay and the Battery Saver Relay. The Acc Delay Relay allows the windows and radio to continue to work for a short time after the key is removed. The relay is controlled by the Generic Electronic Module (GEM) and powers the power windows and the audio unit.
The Battery Saver Relay is triggered by the GEM and controls a lot more items and is probably where your focus should be. Powered by the Batt Saver Relay are:
  • Left and Right vanity mirror lamps
  • Interior/Map lamps (front, rear, and cargo areas)
  • Homelink
  • Glove box lamp
  • Interior lamp relay
-Rod
Headviking
May 14, 2017 07:50 PM
wrhatt
1978 - 1996 Big Bronco
Jun 28, 2016 02:15 PM
Supercab
1983 - 2012 Ranger & B-Series
Sep 26, 2015 08:13 PM
gyrospinup
1997 - 2003 F150
Sep 16, 2011 09:43 PM
djgsolo
Electrical Systems/Wiring
Jan 2, 2004 10:13 PM
