Rear fuel tank strap
I've spent the last hour online searching parts stores trying to find the fuel tank straps for the rear tank. My truck is a cab and chassis and the tank must be a larger option. Every set I find is a strait set of straps, mine need to be "U" shaped because the tank hangs down below the cross member. Any body know where I can order some? My rear tank is hanging by a ratchet strap.
Here is some http://www.ebay.com/itm/Dorman-Fuel-Tank-Straps-Ford-F-100-F-150-F-250-F-350-F-450-Super-Duty-RWD-4WD-/331336347776?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d252f7080&vxp=mtr I know they are flat but may have some for cab and chassis I know the tank is deeper on narrow frame to fit more fuel ,I did at one point use at set from bronco on obs SD 92-96 broncos had taller fat tank like SD f450 but check ROCKAUTO they have everything if you can wait for shipping .Hope this helps.
Option - use the stock straps (e.g. Spectra ST16), and get longer bolts and spacers. As a guide, check out the pic of the install kit that comes with this tank:
Bunger1348
10-19-2014 08:17 AM
4EyedTurd
12-20-2012 11:49 PM
mrlightrail
07-09-2008 02:42 AM
1985 Ford F-150
06-25-2008 02:54 AM
