Sponsored by: Real Truck
backup alarm stays solid on beep
Old Oct 8, 2014 | 08:28 PM
artfuldodger's Avatar
artfuldodger
The backup alarm comes on solid in reverse like I'm about to hit something. The sensors are clean and the truck bumper is spotless. Does this mean one of the sensors needs replacing? The truck is a 2011 F350. Thanks for any help.
Old Oct 9, 2014 | 05:37 AM
redford's Avatar
redford
FTE Leadership Emeritus
I'd say that would be a good place to start.
Old Oct 9, 2014 | 12:56 PM
jdadamsjr's Avatar
jdadamsjr
Agree, but at least check the connections and your wiring for continuity before replacing parts
Old Oct 9, 2014 | 01:30 PM
droldsmorland's Avatar
droldsmorland
Agreed with both. Its usually a sensor. If you apply the parking brake and put it safely into reverse go behind truck and put your ear up to each sensor. Truck doesnt need to be running but the ignition needs to be all the way on. You should be able to here a buzz. The one (or two) not buzzing is the bad one. But do check the wire connector cavity for corrosion, and shorts first.
Pastor Scott
Oct 30, 2016 03:58 PM
tbsexc
May 26, 2012 08:56 PM
Powerstrokin_350
Apr 17, 2012 07:48 AM
dfboothe
2004 - 2008 F150
Dec 17, 2010 12:15 PM
puller45
Apr 23, 2010 07:22 PM
