Sponsored by: Real Truck
How does back up warning system work ?
Old Oct 30, 2016 | 02:49 PM
Pastor Scott's Avatar
Pastor Scott
On my 08 I just picked up...how do you get the back up sensors to work or is it even worth trying ....
thanks
P Scott
Old Oct 30, 2016 | 03:58 PM
RightWingNutJob's Avatar
RightWingNutJob
They should be "armed" as soon as you put the truck in reverse. When you are backing up and an object is within ~6 feet of your rear bumper, the system will start to beep. The frequency of the beeps will increase as you get closer to the object. Once you're within 12 inches, the beeps turn into a continuous tone.
Look in your Owner's Manual for the fuse that controls the Reverse Parking Aid. Check it.
If your system is not working, inspect the sensors on the rear bumper. Look at them closely to make sure that they're not cracked, or that the lenses don't have water inside.
You can test them with the engine off, and the transmission in reverse.
ON FLAT GROUND ONLY!
First set the parking brake. Then put wheel chocks behind your rear tires. Put the key in the ignition and turn it to the "ON" postion, but don't start the engine. Step on the brake, and put the transmission into Reverse.
Go behind the truck - the reverse lights should be ON. Now squat down next to the bumper and position your head toward the side of the one of the sensors. Then move your head in front of a sensor (with your ear closest to the sensor. ) If the sensor is working, you should hear it click faintly each time you move in front of it.
If a sensor doesn't click, check/wiggle/clean its connector on the inside of the rear bumper. If that doesn't help, then the sensor will need to be replaced.
One other thing. It's a used truck. If none of the sensors work, the previous owner may have permanently disabled the reverse sensors by modifiying the instrument cluster... (I don't know how to fix that.)
oldpaintguy
Dec 1, 2015 03:48 PM
pokeycameron
Jan 2, 2014 08:39 PM
dfboothe
2004 - 2008 F150
Dec 17, 2010 12:15 PM
PRexcursion
Mar 10, 2008 05:18 PM
fisherman11
Electrical Systems/Wiring
Aug 3, 2006 08:48 PM
