Pulling glow plugs
Old Oct 8, 2014 | 06:04 PM
Jamie Arceneaux's Avatar
Jamie Arceneaux
Pulling glow plugs
I am in the middle of pulling my glow plugs to replace them and purge the oil and fluid out of the cylinders after changing injector o-rings. I got 7 out with no issues. the last one did not "break free" like the rest. it feels like it is twisting on itself and will break if I continue to torque on it. Should I continue to try to loosen it and hope it doesn't break? If it does break what is the process to get it out?
Old Oct 8, 2014 | 06:17 PM
Justin Jantzen's Avatar
Justin Jantzen
I had something similar happen to me. It was #7 hole. Which is the back one on the passenger side. I tried for prob 15 min and all it would do is spin same as you. Plus I had all the others out so I couldn't put my socket on another one to make sure it was actually in all the way.
I finally gave up and worked on something else for a while and when I came back, it slipped right on. Sure enough it wasn't on all the way before. I guess cause that ones so far back in there it looked like I was straight but wasn't. That's all I can figure out. Cuz I'm pretty sure if it was stripped it'd blow that plug outa there so fast it'd make your head spin.
Not sayin that's for sure what's goin on, but I'd double check.
Old Oct 8, 2014 | 06:23 PM
Jamie Arceneaux
I will be going back at it after I get off at 6am so hopefully its something simple. this is the back one on the driver's side.
Old Oct 8, 2014 | 07:03 PM
F350-6's Avatar
F350-6
Is it an Autolite plug?
Loosen, tighten, loosen, tighten, spray penetrating oil, repeat.
If it's an autolite plug, there's a chance the head is swelled up larger than the hole so don't force it.
Old Oct 8, 2014 | 07:05 PM
Justin Jantzen
Ooo ya I forgot about that! He hopes not....
Old Oct 8, 2014 | 07:08 PM
Jamie Arceneaux
Not sure who makes the glowplug. the rest of them didn't have a brand name on them that I could see. I will say though that I was running off to work so I didn't look all that good.
stoker1995
Apr 25, 2017 06:54 PM
84tanandbrown
Oct 4, 2014 04:13 PM
JamesHajek
Jan 6, 2010 05:47 PM
BigDog83
Oct 11, 2009 05:50 PM
6String
1983 - 2012 Ranger & B-Series
Apr 7, 2005 06:35 AM
