top coating POR-15
Old 10-10-2014, 09:02 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Originally Posted by Fastback460
When is the best time to topcoat it? Some say when it's still tacky, and I have read where other say to let it cure, sand it and then paint it?
DO NOT LET IT CURE. Once cured, you would need to use their tie coat primer to bite into it then you would have to top coat the primer. Save your time and money and just put your topcoat on like another coat of POR15
Old 10-10-2014, 09:19 PM
Fastback460's Avatar
Fastback460
Fastback460 is offline
So topcoat when it is still a little tacky then?
And how much will I need to do just the frame?
Old 10-11-2014, 05:30 AM
Diesel_Brad
Yes, And I hop you are spraying.
a gallon of each
Old 10-11-2014, 07:55 AM
Fastback460
a gallon of each
Everyone has been telling me POR-15 goes a long way. So I didn't think I would need quite that much, glad I asked.
And I was planning on brushing it on.
Old 10-11-2014, 12:03 PM
Diesel_Brad
Better to have too much and not need it than be short and looking for it. Buy the 4 quart special.
Also, Iy are going to HATE brushing it on a truck frame. It is going to take FOREVER(like a whole weekend) and will not be as good as a job as spraying it
Old 10-11-2014, 02:35 PM
Fastback460
I should have mentioned I am probably only doing everything behind the cab when I get the bed off for body work, not the entire frame.
I'll think about spraying it on if I can. I have access to an air compressor, though not sure if it is enough to run a spray gun(never used one before). It's a 5.5HP Emglo that we use for construction.
If I can spray it on, how much do I need to thin it?
Old 10-11-2014, 07:15 PM
Diesel_Brad
RENT a compressor and buy a harbor freight POS throw away spray gun. POR says not to thin it more than 10%. I typically thin it 2-3%
Also don't forget a good respirator.
I would do the WHOLE frame and underside of the truck while you are doing the rear of the frame
Old 10-12-2014, 08:09 AM
Vadis's Avatar
Vadis
Vadis is offline
+2 for spraying it.
I've brushed 1 frame already and it was a pain to know what was covered already after the first coat went on.
That was the deciding factor for spraying mine. That and how quick spraying is. I had 2 coats of Chassis Saver and 2 coats of top coat on in a day. Brushing took a weekend.
Both cases the frames were stripped.
Old 10-12-2014, 08:50 AM
Fastback460
Found out some more about my compressor, it's an 8 gallon and it says it's 12 CFM at 100 PSI. If this one can't handle it, then what should I be looking for if I rent one?
Old 10-12-2014, 10:21 AM
Diesel_Brad
You will be fine with that. Most spray gun are 5cfm or less at 30psi
Old 10-12-2014, 10:35 AM
Fastback460
That's good to know, so then all I need is a cheap spray gun and a respirator.
Old 10-12-2014, 10:45 AM
Diesel_Brad
And lots of tape and plastic to mask of the truck.
Make SURE you tape EVERY body panel seam
  #28
Old 10-12-2014, 12:03 PM
Fastback460
I have plenty plastic and old tarps laying around. And Ill make sure I cover everything but what is getting painted.
Thanks for all the help.
I need to set a day over at the body shop to get the bed off, and then I will make a new thread when I get started.
Fordranchero
07-12-2011 04:25 AM
oldmansimek
Paint & Bodywork
10-24-2006 10:10 AM
DeckedoutF150
Paint & Bodywork
02-12-2005 09:25 PM
WRECK
09-12-2003 08:53 PM
otto
16
07-31-2001 06:14 PM
Quick Reply: top coating POR-15
