Sponsored by: Auxito
Bitten by p0174. Need help
Old Oct 23, 2014 | 06:41 AM
chev2ford's Avatar
chev2ford
Got her all back together. Took about 5 hours to drain the oil. It oozed out. After it started looking better, we removed all spark plugs, put oil in it, removed oil filter, and turned it over. Valve covers and intake was off still. Neat to see the lifters and arms moving in sequence. That oil/water junk just poured out of the filter housing and brake cleaner shot out of the spark plug holes. Bolted everything back up and cranked her over. Purrs like a kitten. Smoked a little then stopped. Idles better than ever. Better response, even sounds better. Haven't driven it yet. Gonna start changing oil this morning. Gonna Change it 3 more times.
What do y'all think about motor medic motor flush?
I thought about putting a qt of transmission fluid in it then change it. Any ideas?
Old Oct 23, 2014 | 09:45 PM
enriched&beyound's Avatar
enriched&beyound
I would think that the 4 oil changes in fairly rapid sequences would flush it out about as well as anything. I prolly would pass on any "can-O-wonder" that you could poor into it.
glad to see that it is running better
Old Oct 24, 2014 | 02:49 PM
chev2ford's Avatar
chev2ford
All is well with the truck, but the code came back again. P0174.
I did replace the O2 Sensor Bank 2 System 1, cleared the code, but it came back. The MAF looks good and has been cleaned. All the vacuum lines looked good when they were off. The EGR hose that connects by the brake booster to the intake looked a bit rough, but noticed no holes. Sprayed with WD-40, carb cleaner, no change in motor rpms. I'm at a loss.
Old Oct 24, 2014 | 04:55 PM
enriched&beyound
Some reading for you>>https://sites.google.com/site/fordf1...P0171P0174-Fix
Old Oct 24, 2014 | 10:31 PM
Bluegrass 7's Avatar
Bluegrass 7
The 174 code sets when the fuel table goes rich 'out of limits' trying to 'correct' for a Lean condition the OX sensor detects. It's not the sensor. The sensor only detects the lean condition and causes the fuel table to go rich letting you know there is a problem. It's the only way the system has to do this..
You need to use a Scanner to 'watch' the short term fuel Trim for a change when you use a flammable spray able to pass through the air leak while looking for the source. Otherwise you may never 'hear' the response to the spray.
Good luck.
mark_5102
1997 - 2003 F150
Jan 1, 2015 11:38 PM
dacrew4009
1997 - 2003 F150
Jan 28, 2014 10:20 PM
97 ONE FIFTY
1997 - 2003 F150
Dec 17, 2012 03:20 PM
rockstarf150
1997 - 2003 F150
Jul 9, 2012 10:53 PM
dcjohnson50
1983 - 2012 Ranger & B-Series
17
Jul 18, 2007 04:58 PM
