I bought one in good shape with a complete wiring harness and plug for $75. I think it was a fantastic deal, considering aftermarket gauges and a new mounting bezel will set you back over $600
Autometer priced out to a grand but I changed my mind and now want New Vintage. I want seven gauges and I am not opting for the budget line.
Great choice. They used LED back lighting.
New vintage made my EGT gauge and air pressure gauge to match my Omega Kustom gauges. I wish I would have known about them before; I would have used New Vintage to begin with.
What did the custom deal cost you? I want to go custom.
I'm going old school. F-550 dash with FOMOCO cluster, a VDO tach and an analog clock off of a Soviet era bus. The clock isn't American, but, it's 12volt, is the correct diameter and I looks cool.
No they're not. You can buy cheap ones, but you can also buy completely custom ones. You can even send in your gauge cluster and say, "Figure out a way to put some gauges in this." I'll be going for the custom set.
Speedometers today are also smart enough that you don't even need a cable going to them and they don't even need to be wired to a VSS (Vehicle Speed Sensor).
They can be run off satellites just like your Garmin or Tom Tom --GPS.
