F500 Cluster?
Old Oct 8, 2014 | 07:21 PM
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by trozei
Do you have a link to his profile? I'd like to send one in to have it retrofitted with modern gauges.
<TABLE id=post12955614 class=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center><TBODY><TR><TD style="PADDING-BOTTOM: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=alt2><TABLE border=0 cellSpacing=6 cellPadding=0 width="100%"><TBODY><TR><TD class=alt2></TD><TD noWrap>Area351 ******** type=text/javascript> vbmenu_register("postmenu_12955614", true); *********>
</TD><TD width="100%"> </TD><TD vAlign=top noWrap>Join Date: Jan 2013
</TD></TR></TBODY></TABLE><!-- / user info --></TD></TR><TR><TD id=td_post_12955614 class=alt1><!-- message, attachments, sig --><!-- icon and title -->Project: F'nstein
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1></TD></TR></TBODY></TABLE>
Old Oct 8, 2014 | 07:29 PM
Gembone's Avatar
Gembone
I am hoping to run across one of these clusters for my truck one of these days. I just want the bezel as I have a set of gauges I can put in it. I think it would improve the visibility of the gauges at night.
I also don't need the switches, but maybe find one with the blank panels still there.
Old Oct 8, 2014 | 07:39 PM
crazed87bronco's Avatar
crazed87bronco
Originally Posted by JEFFFAFA
Just in case Crazed doesn't, if I remember correctly Area351 had extra(s). But I haven't seen him around in a long time.
The better ones I have I'm holding onto for now. I originally got them because I was going to do custom gauges with them and put them in my 71 like the pics above.
I haven't seen him post in awhile actually was thinking about his build the other week. He's another PA member. I know he sold one cluster think he had a white one left?
Old Oct 8, 2014 | 07:42 PM
trozei's Avatar
trozei
Thanks, Jeff. I know how to get a bezel easily from some different guys in the Georgia area on Facebook but I'd rather give an FTE member my money.
Old Oct 8, 2014 | 07:44 PM
ultraranger's Avatar
ultraranger
^YES! That's kind of what I'm after. I want round gauges but the F600 cluster is the only way to do that while still maintaining an OEM appearance. Do you know who owns that cluster? I'd like to ask them some questions.
This is the thread containing the modified big truck instrument cluster by Coupe5oh. (VERY nice modified truck build).
The FORDification.com Forums ? View topic - 67- SWB, CV swap, 2007 3v 4.6/ 5 sp
Old Oct 8, 2014 | 07:46 PM
crazed87bronco
Incase anyone is wondering a 2 1/16" gauge will fit snug in the small gauge holes in the bezel. If you flatten out the raised part around the gauge bezel hole and slide in a gauge it would be a quick easy way to liven things up in the cab. Or you don't need to flatten it but then the gauge has a small gap between the back of the 2 1/16" gauge and bezel.
Old Oct 8, 2014 | 07:47 PM
JEFFFAFA's Avatar
JEFFFAFA
I'd put a fancy "start" button in place of one of the switches.
Old Oct 8, 2014 | 07:59 PM
crazed87bronco
Originally Posted by ultraranger
If you're using the bigger truck instrument cluster in a '67-'69 model F-100 through F-350, the connectors of the big truck instrument cluster are a direct connection to the existing '67-'69 F-100-F-350 connectors on the main wiring harness.
If you have a '70-'72 model truck (printed circuit board cluster) you need the connectors and a short length of the big truck's main wiring harness to splice it into the main wiring harness of the '70-'72 F-100 through F-350. However, any '67-'69 F-100 through F-350 truck will also have the same needed connectors to cut a pigtail from the main wiring harness to connect to the big truck cluster, if it was being installed in a '70-'72 light duty truck.
At some point (possibly '77 or '78) the big trucks also had a printed circuit board instrument cluster.
You can see the circular impressions of this cluster stamping, indicating this an F-500/ cluster with printed circuit board.
This is one of the coolest (modified) big truck clusters I've seen.
I didn't know that about the connectors of the 67-69 years. that's good to know now that I've been toying with a 69. Who knows maybe one of them clusters will end up in that. I only paid attention at what it took to get into a 71 since that's what I originally had in mind for it.
Old Oct 8, 2014 | 09:22 PM
trozei's Avatar
trozei
That guy sure likes his silver...
Old Oct 9, 2014 | 08:39 AM
coupe5oh's Avatar
coupe5oh
What's wrong with silver?😊
Old Oct 9, 2014 | 09:03 AM
ultraranger
Personally, I don't see anything wrong with it. I referenced your truck because I think you have one of the nicest builds out there.
Old Oct 9, 2014 | 09:17 AM
coupe5oh's Avatar
coupe5oh
Thank you very much. Appreciate it. The bezel was a plain white One I got off eBay with no guages. The guage set is from speedhut. You can design them on their website, they are pretty cool. Get a lot of compliments. If there is anything you guys want to know I'd be happy to help.
Old Oct 9, 2014 | 12:09 PM
  #28
trozei's Avatar
trozei
What sizes are the gauges?
Old Oct 9, 2014 | 12:33 PM
  #29
coupe5oh's Avatar
coupe5oh
4" and 2 5/8. I had to cut the raised area around the guages out for them to fit.
Old Oct 10, 2014 | 09:17 PM
  #30
doug51f1's Avatar
doug51f1
I bought one in good shape with a complete wiring harness and plug for $75. I think it was a fantastic deal, considering aftermarket gauges and a new mounting bezel will set you back over $600
