The OP was active last month, you might PM a moderator (tjc transport) and ask him to move your post to a new thread.
I bet it was veggie oil or a mix. I can get biodiesel here in OK and it is green. I have so much used transmission fluid that I add it to the tank at every fill up (1/2 quart or so) and to every new fuel filter.
Now if only I could get my hands on enough to run 100% waste ATF!
I'm sorry, but I'm new to this forum business. how do I get them to move it to a different thread? oh and also it's green when I pumped in the diesel and it turned to this color
I just tried to send you a PM about messaging tjc transport. Apparently you aren't allowed to message yet since you don't have enough time as a member or enough posts. A moderator will probably see this thread and might move your post, or others will end up responding anyways.
I wouldn't worry about the odd color of the fuel. If the engine runs fine then just keep on truckin'.
