Dana 61 troubles
Old Oct 5, 2014 | 03:36 PM
dave2953's Avatar
dave2953
Dana 61 troubles
I recently purchased what I thought to be a Dana 60 with a 3.31 gear. Turns out it's a Dana 61. I was looking to swap out the Dana 60 in my '66 F250 (4.56) I now know this isn't a direct swap but my plan was to reposition the perches and shock mounts. Is this swap as simple as that? Also, I noticed the yokes are different, too. Are they interchangeable? Thanks in advance for your help.
Old Oct 5, 2014 | 04:36 PM
crazed87bronco's Avatar
crazed87bronco
Hope this helps.
https://www.ford-trucks.com/forums/1...1966-f250.html
Old Oct 18, 2014 | 07:14 PM
dave2953's Avatar
dave2953
Thanks for the link. After a little more investigating I found out that the hubs and brakes won't swap from a D60 to a D61 and the yokes are different too. I'm only out $100 so it isn't the end of the world. Guess I will just spend the money for a carrier and gear swap.
Old Oct 18, 2014 | 07:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Doesn't matter if the rear axle is a Dana 60 or 61. What does matter is the year and size of the rear brake shoes.
1966/68 F250 Dana 60 uses a different rear hub than 1969/79 F250 with Dana 60 or 61.
12 1/8" x 2" drum brakes: 1953/65 F250, some 1966/79 F250's.
12" x 2 1/2" drum brakes: Some 1966/85 F250's.
12" x 2 1/2" introduced in 1966, but it depends on the GVW if these brakes are present thru 1985.
1966/79 F250 Camper Special's, 1966/72 F250's w/a 7,500 lb. GVWR have 12" x 2 1/2." 1968/72 F250 2WD's with optional dual piston caliper disc brakes have 12" x 2 1/2" rear brakes..
Old Oct 18, 2014 | 07:54 PM
dave2953's Avatar
dave2953
Anyway to ID what the Dana 61 came out of? I can't see a BOM on it anywhere. C38390 is the only thing I've been able to find. I guess if I knew the year I could find some hubs and brakes to use. Thanks.
Old Oct 19, 2014 | 10:25 AM
NumberDummy
The Ford ID tag is located under two of the bolts that retain the inspection cover to the housing. By now, this tag could be missing.
There may be a separate Dana ID tag located adjacent to the inspection cover, bolted to the housing.
Tag is approx. 2" x 1/2" and has a 7 or 8 digit number stamped on it, similar to this: 603901-1 or 603901-11
Anthony487
Feb 10, 2016 01:34 PM
1972fordhighboy
Feb 20, 2015 02:00 AM
btcrawford429
Nov 5, 2014 08:26 PM
kmorgancraw
Mar 28, 2013 10:11 AM
harriscountry
Jan 15, 2007 10:15 AM
