Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Clogged Drain Lines
Old Oct 5, 2014 | 01:14 PM
bourbondog's Avatar
bourbondog
Clogged Drain Lines
Is it true that if your drain lines are clogged water will backflow to the relay in the fuse box?
Old Oct 5, 2014 | 01:17 PM
projectSHO89's Avatar
projectSHO89
What are you talking about?
Old Oct 5, 2014 | 01:27 PM
bourbondog's Avatar
bourbondog
The relay in my fuse box keeps going bad and I'm try to find out why.
Old Oct 5, 2014 | 01:46 PM
bourbondog's Avatar
bourbondog
I found this on the internet while searching for a solution to my problem:
EddieE wrote: I had a major problem with the running lights and interior lights shutting off while driving, headlights remained on, found out it was a relay that had filled with water, because the water drain had clogged up, backflowing the water behind the fuse box, filling the relay with water.
hmedic
Nov 1, 2024 12:29 AM
Ajk Tek
May 15, 2017 05:28 PM
jballard81
Jul 26, 2013 08:52 AM
KC8QVO
6.4L Power Stroke Diesel
May 18, 2011 10:06 PM
btduckcall
Electrical Systems/Wiring
Dec 3, 2006 07:11 PM
