Surging Cruise Control
Old Oct 4, 2014 | 04:40 PM
Eric Kropp's Avatar
Eric Kropp
Hi, I noticed on my 1993, 7.3 IDI, Manual trans. pickup that it has a very repetitive surge when engaged at say 65 mph. The surge is definitely a "short" or "close" surge, but quite steady. It is not a long type surge that takes you up and down even a mile or two per hour. You can feel it and watch the tach needle move up and down the scale a hundred or so R's constantly. I remember my 6.9 with an auto. trans. and the vacuum servo fluctuated worse that this. This one has the electronic servo and I expected it to be perfect......but, well, I guess nothing is perfect!
Thanks,
V-465
Old Oct 4, 2014 | 10:08 PM
bduemig's Avatar
bduemig
I have the same issue. I changed the differential oil and cleaned the tone ring but it didn't seem to do anything. I also changed the speed sensor, but it got even worse.
After some research, there was at one time a repair of the speedo cluster for a slight surge in the speedo which also affected cruise. I checked with a repair shop and the kit to fix it is no longer available.
Jmatthews
Nov 16, 2009 08:02 AM
Franko72
May 4, 2009 03:12 PM
ttaylor530
Dec 22, 2005 05:19 PM
tsheriff
Oct 20, 2004 08:31 AM
randy_kanada
Electrical Systems/Wiring
Feb 16, 2004 07:02 PM
