cruise keeps truning off.
Old Oct 19, 2004 | 04:49 PM
tsheriff's Avatar
tsheriff
Does anyone have the problem with thier cruz turning itself off.
Old Oct 19, 2004 | 05:58 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
That is something that has never happened to mine.....a few others but never that
Old Oct 19, 2004 | 06:04 PM
Maxium4x4's Avatar
Maxium4x4
Not sure if this applies..........but in the 7.3 the cruise would shut off from the speed sensor going bad located on the drive axle. One other thing.....just a shot in the dark.....any adjustment to cruise and the brake pedal...if you have a hair trigger it may be turning the cruise off.Do you lose your speedometer at the same time for just a sec?
Old Oct 19, 2004 | 08:58 PM
tsheriff's Avatar
tsheriff
My buddy thought it might have something to do with the box. Because i really havent used it since the instasll. Im not to shore about the speedo wasnt looking at the dash at the time.
Old Oct 20, 2004 | 08:31 AM
R1ZOOM's Avatar
R1ZOOM
I couldn't get mine to come on the other day. I was running about 85 on the interstate and tried to "set" it several times with no luck. I went through the sequence several times of turning the cruise on, then hitting set with no luck. I tried about 10 minutes later and it worked fine, and have had no problems since then. Iused to have a Grand Cherokee that's cruise worked intermittently also. If mine acts up again I'll take it to the dealer.
