Throttle Connection
Old Oct 3, 2014 | 02:17 PM
Rollie 1's Avatar
Rollie 1
Throttle Connection
On a 1985 F250 with a 7.5 L and Motorcraft (Holly) carb there is a black plastic block connecting the throttle wire to the carb lever. How do you remove it to separate the carb? It appears to be plastic and I don't want to break it. All the carbs I have worked with have the ball and spring loaded socket but this one appears to be different.
Old Oct 3, 2014 | 04:24 PM
CountryBumkin's Avatar
CountryBumkin
Just insert a screwdriver between the linkage and the cable connector, then gently pry. It is just a spring loaded ball-clip inside that plastic connector. It will pop right off. it snaps back on as easily as it comes off.
apbtpetey
Mar 25, 2013 09:57 AM
KO1960
Aug 1, 2010 11:18 PM
74crwcb429hibPS4spd
Mar 25, 2005 10:24 PM
Billyboy501
Feb 19, 2003 07:33 AM
