Sponsored by: Real Truck
smelling rear end dope
Old Oct 3, 2014 | 10:53 AM
thenaturalist's Avatar
thenaturalist
I have a 2000f 350I have a strong smell of rear end dope I have replaced the brakes and calipers and do not see any leaks why am i smelling a very strong smell....no leaks and pig is full?
Old Oct 3, 2014 | 11:50 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
What the heck is "rear end dope"?
Old Oct 3, 2014 | 12:00 PM
speakerfritz's Avatar
speakerfritz
whats a pig?
Old Oct 3, 2014 | 12:16 PM
phillips91's Avatar
phillips91
I'm a little confused as well. Do you mean you were changing the rear brakes and smell differential fluid?? . I had an axle seal go out on my 97 250 a while back and I smelled differential fluid, but there was definitely a leak and it slung fluid everywhere.
Old Oct 3, 2014 | 01:15 PM
senix's Avatar
senix
I think the pig is the diff.
Old Oct 3, 2014 | 03:01 PM
thenaturalist
I smelled rear end dope ( rear axle oil 80/90) I checked fluid in pig (differential) its fine good viscosity . While looking tires off I noticed the pads on rear needed replacing, upon further examination I noticed the rubber seal housing on pistons in both calipers we rotted, thinking that maybe some dot 3 (brake flude )had been leaking causing the smell.....I replaced all rear brake components and still have oder of rear end dope (diff.fluid )... Sorry I must be to old school for some of you....ie pig, dope..aah the good ol dayzzzz
Old Oct 3, 2014 | 04:40 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
There is a vent on the axle and you may be just smelling fumes from there.
Old Oct 7, 2014 | 08:38 AM
thenaturalist
Thanx ya
Good idea... I seen some light smoke coming out around the rear tire it was definitely rear end oil....I'm thinking that vent might be plunged I will check that and let you know...on another note I love this site (new be) and the knowledge and the response time....thanks to you all hats off!!!!
Old Oct 7, 2014 | 10:39 AM
r2millers's Avatar
r2millers
It been known that "critters" will get into the vent and plug them up. Once on the road and your pig heats up, your dope expands and can create enough pressure to blow out a wheel bearing seal.
Comprende to this old school thread.
desel25
1997 - 2003 F150
May 13, 2012 02:38 PM
crivaro
2004 - 2008 F150
Apr 29, 2012 05:00 PM
biscuit141
1997 - 2003 F150
Oct 11, 2011 10:34 PM
puppypower
Oct 9, 2005 07:38 AM
deananthony
15
Mar 8, 2004 12:40 AM
