Rear end fluid change?
Old Mar 2, 2004 | 09:07 AM
deananthony's Avatar
deananthony
How often do you have to change/add more oil to the rear and front end of a 4x4 truck? I just changed the pinion seal in the rear and added a quart of 80W-90 to it and was curious if i should have drained the entire thing and replaced with new or if what i did was ok, and if I should do the same on the front end?
Thanks
Old Mar 2, 2004 | 02:24 PM
Superdave's Avatar
Superdave
deananthony
It probably would have been a good idea to have changed it.
Do you know how long the oil has been in there?
Old Mar 2, 2004 | 03:12 PM
deananthony
125000 miles, it was milky looking and about a quart drained out of it
Old Mar 2, 2004 | 03:50 PM
NascarMark06's Avatar
NascarMark06
You must have had some moisture in there. I recommend taking off the cover and replacing all the fluid.
Old Mar 2, 2004 | 04:09 PM
hostile413's Avatar
hostile413
i agree with nascarmark, on my 4-wheeler, anytime i take it through a creak or river, i always change the oils..anytime your fluids have a milky appereance, means moisture is present
Old Mar 2, 2004 | 07:19 PM
jessfactor's Avatar
jessfactor
ford says every 100k miles. if the fluid has never been changed it would deffinately be a good idea to do so. i'm gonna do mine soon now that the weather is getting nicer.
Old Mar 3, 2004 | 01:19 AM
Superdave's Avatar
Superdave
deananthony
Agree with the others.
That oil needs to come out as soon as possible, if its milky looking.
Old Mar 3, 2004 | 05:46 AM
KeelarPluto's Avatar
KeelarPluto
Milk is Good for the bones though
I put water in all my oils to help the cooling.....
Old Mar 3, 2004 | 06:39 AM
hostile413's Avatar
hostile413
keelarpluto.....you really put water in your oils?? or were ya joking?
Old Mar 3, 2004 | 07:38 AM
deananthony
Thanks for the input, its always good to get advice from people that really know about trucks
Old Mar 3, 2004 | 07:46 AM
deananthony
Now i am curious about the Transmission and routine maintence for it. I have the T-18 4 speed tranny, what needs to be done to ensure the life of this cast iron beast
Old Mar 3, 2004 | 10:28 PM
Superdave's Avatar
Superdave
deananthony
If in doubt, oil does not cost that much, drain the transmission and the transfer case too.
Old Mar 4, 2004 | 05:28 AM
Supercab's Avatar
Supercab
Cool
I'd like to jump in here if I could, with a related question: my '94 F150 2wd with 3.55.1 Traction Lok (posi) rear end has 90k on it, I'm thinking its time for a gear lube change, I've heard that I must get something called friction modifier from Ford and add along with the fresh gear lube for the posi unit, is this true? and if so can I use something else from anouther manufacturer instead? and would it be advisable to go to a synthetic lube at the same time? thanks for any imput.
Old Mar 4, 2004 | 08:38 AM
underDAWG's Avatar
underDAWG
MOst of the gear oils sold in the stores have friction modifier added, for example Mobile 1 or RedLine, etc. Check the label. HTH
Old Mar 4, 2004 | 08:42 AM
underDAWG's Avatar
underDAWG
Actually I installed an old window air conditioner unit in each my front and rear diffs. It cools much better than water. .
Later,
