ZF 5 Rebuild??
Old Oct 3, 2014 | 10:20 AM
F-250 restorer's Avatar
F-250 restorer
ZF 5 Rebuild??
I've decided there's no way I'm paying $400--$800 for a used sb ZF from a jy, when it has untold miles on it.
So I'm considering pulling one myself and rebuilding it.
Has anyone rebuilt a ZF manual?? Is it feasible for a novice? Do you have a link for how to, or a source for info? Nothing on youtube.
I depend on my truck and don't want to put a trans in it that is questionable.
Thank you. k
Old Oct 3, 2014 | 04:45 PM
whc8100's Avatar
whc8100
Here's a good link, I got lucking with my ZF when I bought it, threw it in and it worked just fine.
ZF5 (S5-47) Rebuild - FSB Forums
Old Oct 3, 2014 | 05:19 PM
dlburch's Avatar
dlburch
http://www.zf.com/media/media/docume...ce_manual_.pdf
Old Oct 4, 2014 | 12:04 AM
F-250 restorer
Thank you so much to all who responded. Your links were a great help. Also, thanks for the pm link. Very helpful. k
Old Oct 4, 2014 | 02:02 AM
privateer, eh's Avatar
privateer, eh
You probably know this already buuut, Theres a small block and big block trans and the big block has a diesel ratio and a gas ratio
Old Oct 4, 2014 | 09:37 AM
ShaneNP123's Avatar
ShaneNP123
It's irrelavent, he is putting the ZF behind a 300. A deisel or BB trans would be useless to him.
Old Oct 4, 2014 | 07:53 PM
F-250 restorer
That is true, and it's a 2x4. I'm considering just buying a used one and knowing that I'll have to rebuild it.
I found an old old friend who runs Tri County Gear, so I may go back to using a Borg Warner T85N, with the R11 overdrive. Having a buddy able to make gears lessens my fears about not being able to find parts. It cost less and be less trouble b/c it bolts right to the C6 without d.shaft lengthening.
Old Oct 5, 2014 | 08:24 AM
Fordworth's Avatar
Fordworth
Have you considered the Mazda 5 speeds that Ford used to put behind small blocks in F150s? I believe you can get them cheaper than the ZFs.
Blue Rebel
70
Jun 6, 2016 10:37 AM
lil ford mec
Mar 25, 2015 09:32 PM
PAwhiteboy
Apr 20, 2011 09:22 AM
unclejesse67
Nov 22, 2007 04:13 PM
