Sponsored by: Real Truck
Possible Fuel problems
Old Oct 2, 2014 | 03:25 PM
Cincyfrantic's Avatar
Cincyfrantic
I have a 2000 Ford-F250, V10, 6.8 liter Gas
THe issue is that when I try to start the vehicle it will start, but then start to idle real low and then die. If I try to restart sometime it will and sometimes you have to let it sit. I can also pump the gas and it will someyimes start. Any help would be greatly appreciated.
Old Oct 2, 2014 | 04:16 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Lots of things it could be.
Is it turning the CEL on? If so, what codes is it showing?
Old Oct 2, 2014 | 04:26 PM
rockcrusher 24's Avatar
rockcrusher 24
idle
my guess is a bad idle air control motor,my ford van did the same thing
Old Oct 2, 2014 | 05:08 PM
redford's Avatar
redford
FTE Leadership Emeritus
+1 on the IAC. That is where I would start looking.
Old Oct 2, 2014 | 06:09 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
That's just one of a myriad of possibilities.
You can try whacking the IAC with a screwdriver handle just to see if that loosens it up, but more info is needed to make a more educated diagnosis.
Old Oct 2, 2014 | 06:41 PM
Cincyfrantic
[QUOTE=Ltngdrvr;14711090]That's just one of a myriad of possibilities.
You can try whacking the IAC with a screwdriver handle just to see if that loosens it up, but more info is needed to make a more educated diagnosis.[/QUOTE
I replaced the idler control valve and there are no issues once it starts. When it won't start I can sometimes push the gas down and it will start. I'm unable to check for codes because it's never happened when I have it somewhere that can check.
Old Oct 2, 2014 | 08:25 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
[QUOTE=Cincyfrantic;14711188]
Codes are stored and light won't go out until someone turns it off.
rackhound
Dec 22, 2011 06:50 PM
rockylane
Sep 10, 2011 06:37 PM
dermodytp
1997 - 2003 F150
Feb 22, 2010 10:31 PM
egalaxie
Oct 27, 2008 10:37 PM
antdebit
Nov 11, 2006 10:57 AM
