turns over but won't start - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-08-2011, 10:54 AM
rockylane
rockylane is offline
rockylane is starting off with a positive reputation.
My 1999 f350 with a triton v-10, sometimes when i shut it off and then try to restart it, it will turn over but won't start. If i let it sit for awhile sometimes minutes to hours it will fire right up and i may go weeks before it does it again. Anyone else have this problem or know the fix?
Old 07-08-2011, 05:44 PM
DavidB
DavidB is offline
DavidB is gaining momentum as a positive member of FTE.DavidB is gaining momentum as a positive member of FTE.
Sounds like the IAC (idle air control) valve is sticking. The next time it does not start, try pressing the accelerator about 1/3 to 1/2 way down while cranking and see if it starts. If so, clean or replace the IAC.
Old 07-11-2011, 10:30 AM
rockylane
Thanks I'll give it a try
Old 09-10-2011, 06:37 PM
Ford Blues
Ford Blues is offline
Ford Blues is starting off with a positive reputation.
I have some what the same issue. It will start, but only run 2-3 seconds, and then not start again. Does not idle just dies. Then if I wait minutes/hours it will start again, still does not stay running. We put a new pump in last year and just replaced the relay switch. What am I missing?
craig auto body guy
09-29-2015 09:35 AM
Kevin Matthews
09-07-2015 12:44 PM
Jly154
02-12-2015 09:39 PM
frhrwa
06-11-2014 05:00 AM
blwtide1
09-20-2012 01:31 PM
Quick Reply: turns over but won't start
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
