Truck started to stall. Pulled over and it would start idle a little then die. After a few minutes it would not start at all. I have 40 psi on the fuel rail, new plugs, have spark and pulse. It will idle if i spray starting fluid in the intake. Any suggestions would be great. thanks
Tim
what year is it 2002? What engine?I don't own one of these and i don't have a manual. Sounds like a fuel issue.What is the FP suppose to be. did you do a koeo, a koer and did you let it sit to see how long and how much it dropped. Have you changed the fuel filter?
You should clean your iacv and try the airpedal all the way to the floor. I don't think that is the issue though . The OP said it will idle if he uses starter fluid which means it is prob not an Air issue. IMHO
