Offroad & 4x4
Front diff limited slip?
Old Jul 15, 2003 | 11:04 AM
cwb's Avatar
cwb
How much will a heavy duty posi unit like an Auburn affect steering when installed in a front diff?
Old Jul 15, 2003 | 11:09 AM
jbalestri's Avatar
jbalestri
It shouldn't effect it with the hubs unlocked, because you are not turning the axles.
It should probably make it harder to turn when the hubs are engaged, whether the t-case is or not because you have added extra mass to move. Just like when you engage them with an open diff, the steering gets a little firmer. I would expect that you would see it get even more firmer.
No real world experience here, but just what I would expect to see.
Old Jul 15, 2003 | 11:40 AM
proeliator's Avatar
proeliator
Auburns are pretty tight, but other than in a situation where it is working (say, corning on ice, or you are really nailing the gas in a corner) you should be fine. I ran Powrloks in the front of one of mine (another really tight limited slip) and never really noticed it except in the above mentioned situations. The caveat that JB gave you regarding steering with hubs locked vs unlocked is dead on.
Old Jul 15, 2003 | 12:27 PM
heep70's Avatar
heep70
I run a Power-Loc in my D44 up front. With it ingauged and now having P.S. in my pickup I can fell a slight difference in stiffness and I can also feel the clutches pop if I bind it up. Really there is not much of a drastic difference at all between an open or loaded frontend. Not unless you don't have P.S.. Then be prepared to do some serious worken in getting that wheel turned.
jeffbradbury7
1983 - 2012 Ranger & B-Series
Jan 12, 2016 07:05 PM
Diesel_Brad
Nov 18, 2015 07:04 PM
SuperDoodie
Oct 21, 2011 06:57 PM
cravenc
1997 - 2003 F150
Mar 15, 2006 07:55 AM
fors43
1978 - 1996 Big Bronco
18
Jan 12, 2003 02:11 AM
