Rocker Arm Mounts
Old Oct 4, 2014 | 09:47 AM
Christof13T's Avatar
Christof13T
On the pic of the pushrod end...
Are those 'nicks' i see... or reflections?
Those little diddys what look like little lines intented kinda make me a wee bit nervous.
I would venture to guess they are from slivers of piston rings. That is if im not just seeing some optical illusion... with your compression #s this theory is further supported.
I agree that a look at the underneathy parts of the heads are definitely in order, but as I have said time and time again... I would not pull the heads unless the motor is on a stand... safely out of the truck.
Fortunately... also due to the compression #s... at worst i e'spek yer lookin at a rering kit and a valve lapping. If a couple holes are chewed up... a couple sleeves set in shouldn't be all that bad at a scrupulous machine shop.
Old Oct 6, 2014 | 07:11 PM
carl2591's Avatar
carl2591
that the problem with cell phone cameras.. they suck for close up work.
I remember reading somewhere about re-torquing the rocker arm hold down parts? some say it helps to quiet the rattle a bit..
any truth to that.??
Old Oct 6, 2014 | 08:54 PM
bkuuz1's Avatar
bkuuz1
Christof13T.,
I'm not sure why it looks like it does. I do not feel anything necks on the ends of the push rods. But, I'm wondering if the the rocker arm wear might be from the low pressure oil pump not supply oil pressure quick enough? Trying to justify why the rub marks.
Old Oct 7, 2014 | 08:17 AM
Tugly's Avatar
Tugly
My rocker arms have wear - but I have a lot of miles. The copper coating on the end of my pushrods is long gone, I replaced a couple of them as an experiment on #7 - no change. I suspect the copper coating is to reduce wear, because it's such a soft metal.
Kyle Wood
Nov 6, 2016 04:11 PM
Thinlizzy13
Oct 11, 2015 03:47 PM
Flip4ford
Kansas Chapter
Nov 5, 2013 07:51 AM
tonpartain
19
Feb 25, 2006 07:37 AM
