C6 Real Seal Replacement
Old Jul 15, 2003 | 06:05 AM
Sebago Frye's Avatar
Sebago Frye
Hey guys, anybody ever changed a real seal and bushing on a C6 tranny? If so, do you have to remove the rear tailpiece or can you do this without removing this rear housing. All the books I've seen are unclear on this. Thanks
Old Jul 15, 2003 | 10:48 AM
steve83's Avatar
steve83
Which "all books" are you using?
I'm not up on automatics, but I've heard the C4 is similar to the C6 - check out this page.
Old Jul 15, 2003 | 03:40 PM
Sebago Frye
Thanks, the exploded diagram for the C4 looks like nothing other than that end seal holds that bushing in. I'll give it a try
Old Jul 15, 2003 | 04:52 PM
rclarke's Avatar
rclarke
The seal is fairly easy to change with some careful hammer and chisel work. The bushing is pressed into the housing. If you have access to the ford tool for pulling it out it is an easy project too. Without the special tool you will have to remove the extension housing and drive the bushing through before driving the new one in.
Old Jul 16, 2003 | 06:15 AM
Sebago Frye
THANKS rclarke! does pulling this tailpiece involve much. Are we looking at much fluid loss or just a quart or two. I'll tear into anything, that's why I have a 1982 truck. Most of the "fun" is tinkering. (something my wife is just begining to understand, she thinks I bought it to just drive).
Old Jul 16, 2003 | 06:57 PM
rclarke's Avatar
rclarke
If you raise the vehicle in the rear to work on it you may not lose more than a few drops of oil. Get a new extension housing gasket. The rear trans mount is on the extension housing, you should be able to raise the trans a little and get the rear mount out of the way. Tighten the extension housing bolts evenly.
Old Jul 17, 2003 | 06:06 AM
Sebago Frye
Thanks
96_4wdr
Aerostar
20
Jan 15, 2024 12:06 AM
markeyd
13
Jun 18, 2015 12:56 PM
rews2
Mar 19, 2015 05:23 PM
Jklnhyd
May 18, 2014 01:21 AM
Eallend7
Dec 9, 2012 09:34 PM
