Rear main seal question
Old Dec 9, 2012 | 08:44 PM
Eallend7's Avatar
Eallend7
Okay so removing the rear main seal is pretty self explanatory, remove the "crankshaft cover" which the seal is housed in im assuming, and when you do that it will expose that "upside down V" gasket", correct? When removing the "crank cover" or whatever the real name is for that, will oil come spilling out? i got it unbolted and then thought....i hope this isn't holding in a b unch of oil i mean it is right about the oil pan. do i have to drain the oil to remove that plate?
Old Dec 9, 2012 | 09:08 PM
84-6.9L's Avatar
84-6.9L
That is well above the oil level. You will be just fine. You will need the V gasket too. Just pull the plate and inspect the crank and make sure it doesn't have a groove in it.
Old Dec 9, 2012 | 09:34 PM
Eallend7's Avatar
Eallend7
okay, just making double sure! i see them sold with the rear main and crank cover seal together so i'll just order that here soon. its comin along!
FordF350Baby
May 19, 2009 08:05 PM
87carbed
13
May 21, 2005 09:08 PM
hster
18
Aug 27, 2004 08:07 PM
slmd350
1978 - 1996 Big Bronco
Feb 18, 2004 01:17 AM
pjslawncare
Dec 13, 2003 03:37 AM
