Modular V10 (6.8l)
cruise control sensor
Old Sep 29, 2014 | 09:08 PM
demonhead's Avatar
demonhead
My cruise control sensor on the master cylinder started leaking brake fluid-wich i believe was a recall so i went to parts store bought a new sensor that came with a wire to plug the new sensor in Now my cruise control isn't working Any ideas on how to fix this?
Old Sep 30, 2014 | 06:19 AM
projectSHO89's Avatar
projectSHO89
Did you swap out the recall harness also? If not, its fuse is probably blown.
Old Sep 30, 2014 | 06:47 AM
demonhead's Avatar
demonhead
i did put the new harness in but i think there is a fuse there i will check it
Old Sep 30, 2014 | 12:57 PM
demonhead's Avatar
demonhead
ok i took out the link with the fuses it had two both were good and connected it without that link still nothing cruise control was working fine before this problem
Old Sep 30, 2014 | 03:23 PM
pappy19's Avatar
pappy19
My cruise control sensor went out a couple of months ago and my mechanic replaced it and mine has worked fine ever since. Did you check the brake pedal to see if the there could be a connection there?
Old Sep 30, 2014 | 07:54 PM
projectSHO89
Check the new pressure switch for continuity and see if it's actually any good.
Old Sep 30, 2014 | 08:20 PM
demonhead's Avatar
demonhead
its working thanks for your help i just dont have a light on the dash that says its working thought i did maybe the bulb burnt out anyhow it works
lawnspecialties
Dec 16, 2017 08:35 AM
German Joe
Mar 7, 2012 12:43 AM
tydel
Modular V10 (6.8l)
Aug 10, 2011 05:57 PM
hornsurgeon
1997 - 2003 F150
Jul 13, 2010 08:27 PM
RBRADBURY9753
Dec 13, 2004 06:20 PM
