Stock Cam
Old Sep 29, 2014 | 05:04 PM
mtntop1's Avatar
mtntop1
Stock Cam
Does anyone know what the max lift and duration the 95 stock 302 engine can take.
Old Sep 29, 2014 | 05:12 PM
Conanski's Avatar
Conanski
0.500" lift should be considered the maximum as the stock heads don't flow any more beyond that and that is about all the stock springs will handle before coil bind, but also note springs should also be upgraded if rpms are pushed beyond stock levels. Duration could be as high as 280 degrees at that lift without any P-V clearance issues(this varies depending upon the exact combination of parts used) but if this is a street truck motor you want to keep total intake duration in the mid 260's or less.
Old Sep 30, 2014 | 06:16 PM
mtntop1's Avatar
mtntop1
Thanks Conanski
Old Oct 2, 2014 | 04:44 PM
mtntop1's Avatar
mtntop1
What about max lift before valve to piston contact
likethefords
Sep 29, 2022 11:26 PM
pipman76
May 20, 2008 06:33 AM
reed1951
Oct 30, 2006 11:00 PM
pat67shorty
May 19, 2003 02:55 PM
blue66f100
Feb 11, 2002 01:47 PM
