Clutch replacement
Old Sep 29, 2014 | 01:39 PM
bradpowell3557's Avatar
bradpowell3557
Clutch replacement
2000 F350 superduty 4X4 6 speed transmission. Looking to replace clutch. Any recomendations on brand and model? I want a good one. Not looking to race or pull a lot of weight all the time.
Old Sep 29, 2014 | 01:41 PM
timmyboy76's Avatar
timmyboy76
dig my "stock' power valair clutch assy. get the updated clutch fork if its not installed already.
Old Oct 3, 2014 | 11:50 AM
bradpowell3557
maybe its not the clutch. after pumping foot pedal several times it started working. Is it possible that the Hydraulic clutch system will work sometimes and not other times?
Old Oct 3, 2014 | 11:52 AM
bradpowell3557
Could a TS 6 position tuner have a effect on clutch and transsmission?
Old Oct 3, 2014 | 12:09 PM
timmyboy76's Avatar
timmyboy76
no...id replace the m/s assy anyways. Seems to be a 50k mile maintenance, anyhow. Advance Auto has them in all aluminum..#pf9021.
Remove the slave from tranny housing, and measure the distance from housing to clutchfork. Stick tape measure in where slave goes. Should be 2-1/2in - 2-3/4in space...if more, replace clutchfork with upgraded one
Old Oct 3, 2014 | 12:36 PM
bradpowell3557
Thanks for the quick reply
X1Lightning
Jan 9, 2014 10:14 AM
rob1
Jan 15, 2006 12:31 PM
big block power
Oct 2, 2002 09:31 PM
