Sponsored by: Real Truck
LSD
Old Sep 29, 2014 | 10:09 AM
MikeyM's Avatar
MikeyM
LSD
No, not that LSD. Low Sulpher Diesel. I know you're not supposed to run it in the new trucks, but what are the ramifications if you run a few, say 5 tanks, and then return to running ULSD. I want to make a run to Baja, and in Baja Sur they only have LSD. I know the the Ford position,--- DON:T, and some people saying they did. Are there additives that would help?? What say you boys and girls .
Old Sep 29, 2014 | 12:53 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
What year & model of engine?
Old Sep 29, 2014 | 01:38 PM
senix's Avatar
senix
Profile says 2013.
So I assume a 6.7. I would not recommend very much as you will have a lot of regen's
Any chance you can scout out some other fuel sources?
Also water is bad..and I would be very careful of the fuel source.
Old Sep 29, 2014 | 01:56 PM
MikeyM's Avatar
MikeyM
2015 Lariate, 6.7. I was going to take Maybe 20 gals with me of the ULSD and dilute what tanks I had to fill. I'm not figuring on needing more than about 4 tankfuls max. They have the good stuff in the northern part, so the whole trip won't be on LSD.
Old Sep 29, 2014 | 03:15 PM
fordman19762003's Avatar
fordman19762003
I'd buy an Aux tank and take enough fuel to get you back north to where the good stuff is.
Old Oct 1, 2014 | 11:25 PM
Yahiko's Avatar
Yahiko
Bring all the 6.0 and 7.3 people back some of the LSD.
Sean
jaynik123
6.4L Power Stroke Diesel
Jul 1, 2016 03:48 PM
97biostroke
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jan 17, 2010 04:44 PM
El VAQUERO
18
Jan 12, 2009 08:58 PM
Storm
Nov 18, 2007 03:02 PM
