copper drain plug gasket
Old Sep 28, 2014 | 03:37 PM
sanjoe's Avatar
sanjoe
what is the proper way to install ford copper gasket, bevel side against pan or flat side against pan? thanks in advance.
Old Sep 28, 2014 | 08:09 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Mine stays on the bolt when I remove it but I guess if it came off I would put the beveled side of the washer towards the head of the bolt.
In aviation there are Belleville bolts with matching washers. The radius under the head of the bolt where it meets the shank is is much larger than normal bolts and the washer has a matching radius. Normally the item the bolt is connecting to is flat and has no need of a bevel.
Old Sep 29, 2014 | 01:50 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Proper way is to pick up a Fumoto valve for the drain plug on the oil pan.
Really, Vancouver Ford charged me $15.95 for that washer. I went with Fumoto.
Search Results | Fumoto Engine Oil Drain Valves
Old Sep 29, 2014 | 10:13 AM
sanjoe's Avatar
sanjoe
Thanks guys.
Old Oct 1, 2014 | 11:16 PM
Yahiko's Avatar
Yahiko
Sheep Dip!
I got one from my local dealer Korum Ford for only $4.00 and I thought that
was high for what it is.
Sean
BillyBob69
Aug 12, 2018 06:24 PM
BillyBob69
Apr 27, 2017 10:00 PM
Matt1966
17
Dec 5, 2016 11:57 AM
RPinNEB
Aerostar
Apr 4, 2005 10:54 PM
