Help...engine mount position!
Old Sep 28, 2014 | 03:21 PM
tbm3fan's Avatar
tbm3fan
I can't believe that I am not going to get my engine back in today, need to return hoist, as I can't recall the correct direction for the FE mounts. Either the vertical metal lip is to the front or to the rear of the truck. The last thing I need is to have it on wrong, lower the engine, and get stuck taking it back out. Picture below show my mount with the metal lip along the bottom which takes a vertical position when on the engine.
Old Sep 28, 2014 | 04:30 PM
tbm3fan's Avatar
tbm3fan
Never mind solved the problem by buying new ones. While getting them noticed two places cannot spec out the correct upper radiator hose for the engine. Both came out with a slightly twisted in two planes upper hose but not definitely not a lower hose. I see this will require online searching now.
Old Sep 28, 2014 | 05:10 PM
JefflovesF250s's Avatar
JefflovesF250s
Steel flange on side towards rear, exposed rubber towards front. Jeff
Old Sep 28, 2014 | 05:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5TZ-8260-J .. Upper Radiator Hose (Auto-Lite KM-244) / Obsolete/Superceded
Applications: 1965/66 F100/250 352 & F350 352 M/T with SRW
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 1 = 812-359-4965.
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
NOS ONLY in San Jose CA has 3 = 800-667-6659.
GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959.
C5TZ-8260-J was replaced in 1967 with C7TZ-8260-B (Auto-Lite KM-206) / Obsolete/Superceded
New applications: 1965/67 F100/250 352 & F350 352 A/T & M/T with SRW.
NOS PARTS LTD has 1.
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
C7TZ-8260-B was superceded (replaced) in 1969 with a flex hose.
P-51 Mustang
Jun 14, 2019 12:35 PM
jghelm
Jul 2, 2017 02:23 PM
Riderman
Aug 22, 2016 08:27 PM
mzerega
Large Truck
Feb 11, 2015 08:12 AM
BossFan
Aug 10, 2011 11:15 AM
