Hey NumberDummy!
Hey NumberDummy!
I need some help...I have a 1964 F100 (F10CP460772) and when I took the bell housing off I found that someone had used front motor mounts in place of rear mounts. Naturally, I decided to put the correct mounts back on. All sites led me to a two piece mount where one of them is a "u" shape that straddles the crossmember. The ones I bought are interchange 2119 for the upper and 2121 for the lower. There appears to be no issue with the lower, it fits inside the crossmember fine, however the upper is about an inch too narrow to fit over the crossmember. The crossmember does not appear to have been changed as best as I can tell. I'm stuck. Any ideas?
I need some help...I have a 1964 F100 2WD (F10CP460772) and when I took the bell housing off I found that someone had used front motor mounts in place of rear mounts. Naturally, I decided to put the correct mounts back on. All sites led me to a two piece mount where one of them is a "u" shape that straddles the crossmember.
But, the rears are not the same 2WD vs. 4WD .. 2WD is different.
Genuine Ford parts are obsolete, some are available NOS
Most of the following are repro'd, but I don't know if the upper rear is repro'd, because only two sources have 3.
AFAIK: The following parts are NOS (but Carpenter's may be repro's based on the quantity he has).
1961/64 F100/250 292 2WD/4WD:
1) C1TT-6A061-C .. Upper Front 'donut' Rubber Insulator / Obsolete/Reproduced
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
1) C3TZ-6068-D .. Lower Front 'donut' Rubber Insulator / Obsolete/Reproduced
NOS PARTS SOURCE has 1.
NOS PARTS LTD in Waxahachie TX has 3 = 972-937-2201.
GREEN SALES CO. in Cincinnati OH has 5 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 474 = 800-476-9653.
1961/64 F100/250 292 2WD:
2) C1TT-6A027-C .. Lower Right & Left Rear 'donut' Rubber Insulator / Obsolete/Reproduced
CARPENTER NOS OBSOLETE PARTS has 38.
GREEN SALES CO. has 83.
2) C3TZ-6038-A .. Upper Right & Left Rear Rubber Insulator / Obsolete - Reproduced?
NORTZ & VIRKLER FORD in Lowville NY has 1 = 315-376-6594.
NOS PARTS LTD has 2.
itsmywifestruck
03-14-2009 07:24 PM
