Sponsored by: Real Truck
transmission issues, 1999 v10
Old Sep 25, 2014 | 05:09 PM
Tommy S. B.'s Avatar
Tommy S. B.
I recently bought an f250, v10. I would like some advice/ suggestions on how to care for the truck. The truck is a 99 and I have read of problems specific to the heads and cps. My truck seems to have a slam when shifting. The transmission fluid is clear and smells good. Any insight?
Old Sep 26, 2014 | 10:24 PM
phillips91's Avatar
phillips91
If your transmission fluid is clear then that would explain your problem. It should be red . Can you give us a little more info on the truck? Miles, service records, prior usage(if known), etc? Congrats on the new truck too and welcome to FTE!
Old Sep 26, 2014 | 11:17 PM
Tommy S. B.
Thank you
I apologize. I mean the tranny fluid is clear meaning not burnt looking. It is red.
The truck has 137,000 miles. I have no knowledge of prior usage. I have recently hooked it up to a scanner and codes indicating a miss on five shot. I changed the cp and the code stopped.
Old Sep 27, 2014 | 06:06 AM
hodge5's Avatar
hodge5
The previous owner chould have put a shift kit in it.
Old Sep 27, 2014 | 06:58 AM
phillips91's Avatar
phillips91
No need to apologize. I knew what you meant and was just giving you a hard time . Does it have any grinding type of noise along with it or does it just shift more firmly than it should? Does it do it all the time or intermittently? All gears or certain ones?
ligito
Feb 3, 2016 09:29 PM
flyboyaviator
Jan 29, 2015 10:41 PM
dudewayne
Dec 9, 2009 06:51 PM
Bdox
Modular V10 (6.8l)
May 15, 2007 05:44 PM
MADDG
Modular V10 (6.8l)
Aug 20, 2002 09:46 PM
