2004 6.0 stalling
Old Sep 27, 2014 | 01:47 PM
Tlid1011's Avatar
Tlid1011
I'm not sure and yes have tried with icp unplugged. I filled a 15 quart oil pan it over filled and had a 5 gallon bucket almost a quarter filled
Old Sep 27, 2014 | 01:58 PM
jdb1930's Avatar
jdb1930
The answer is yes, having that much oil in the system can cause all kinds of crap to happen. Blow out seals, o-rings, etc.
I would start with a scangauge and check all your sensors. It sounds like you have a high pressure oil system leak, but it will be easier to tell once you actually check the icp, ipr, ficm, sync, etc values.
Old Sep 28, 2014 | 07:57 AM
Super Duty Service's Avatar
Super Duty Service
Former Vendor
Id be draining the oil,,, leaving the drain plug out and make sure the fuel isn't diluting with oil. You can cycle the key but obviously do not crank the engine. It's wise to double check any diagnosis before jumping to conclusions.
Old Oct 22, 2014 | 08:49 PM
cheezit's Avatar
cheezit
Do you have an egr throttle plate? If so disconnect it and see what happens.
Do you get a p1000 dtc or a system pass message when chevking for codes?
When it dies does the glowplug light come on?
Disconnect the ebp and see what happens?
Katie Isabel Hunt
Feb 25, 2018 10:40 AM
mikeycars
Jan 1, 2017 09:51 PM
pendukasafaris
Nov 20, 2013 10:02 AM
alexisvfd
Apr 15, 2012 03:29 AM
gartho
Aug 21, 2009 12:18 PM
