cab bushing puller tool?
Old Sep 23, 2014 | 12:50 PM
1994F2507.3L's Avatar
1994F2507.3L
Does anyone have a writeup with pics of their cab bushing puller tool? I've searched and read but haven't come up with anything really solid and I'm looking to do these bushings soon but my truck is my DD right now so I need to be prepared and able to knock this job out pretty quick.
Old Sep 23, 2014 | 01:17 PM
fordman67's Avatar
fordman67
6" long piece of 3" exh pipe with a length of 7/16 all thread,nut,washer and a heavy piece of material with a hole to be the back stop.thread the all thread from bottom and use the but to pull the lower parts down and out ..
Check that rad support.the rust up front can make for a mess getting it apart up there
Old Sep 23, 2014 | 01:27 PM
1994F2507.3L
I've already done the rad support I cut it all out and replaced the mount bracket and all. Now it's on to the 4 that actually support the cab, which everything I've read says it's a terrible job, if I go back with energy suspension bushings do I need some kind of sleeves for the bolts? I priced everything through lmc and came up almost 300 dollars where energy suspension is 60ish
Old Sep 23, 2014 | 01:29 PM
1994F2507.3L
And if I'm reading what your saying right I need to remove the bolt from the top, then run the all thread up into the nut piece from the bottom then pull down is that correct?
Old Sep 23, 2014 | 02:03 PM
LeoJr's Avatar
LeoJr
Yes, but that pulling is going to be long and hard. Some suggest running that bolt through a chain, attach the other end of the chain to the frame of the floor jack, and lift the truck, pulling them apart.
I think it is easier to pull them into a pipe of some sort. I didn't have pipe large enough so I had to flare mine out.
But the notch, or legs, help on the rear driver's side bushing. It's sorta buried, and you will have to remove the rock plate and loosen the tank.
The threaded rod bolts into the bottom, the legs get pushed to the frame, the double nut lets me hold the threaded rod from spinning, the long barrel nut is what applies the tension.
When they eventually come apart, cut just the flared part off so next time is easier. But no more as these have to sleeve into themselves.
You may want to loosen your fronts again as I found it is easier to jack up one whole side, replace the bushings, set it down with the bolts all loose, then do the other side.
The whole cab is loose so don't slide the cab off the frame or into the bed.
Old Sep 23, 2014 | 03:20 PM
quesey's Avatar
quesey
I always just put a long bolt back into the bushing and drive it out with a hammer. From the top
Old Sep 23, 2014 | 04:06 PM
Diesel_Brad's Avatar
Diesel_Brad
You must have looked REAL hard....
https://www.ford-trucks.com/forums/1...find-them.html
Old Sep 23, 2014 | 04:52 PM
1994F2507.3L
That thread was defiantly not on the top when I started lookingetting this morning lol and doesn't even come up when I search cab bushings on my phone at least not in the first 20 or so links
Old Sep 23, 2014 | 05:45 PM
fordman67's Avatar
fordman67
It was not a terrible job on the cab.those 4 could be done in a few hrs since you have already got the hard part done previously.
Old Sep 23, 2014 | 08:55 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel
Not sure how much rust the OP or everyone else had in their rig at time of pulling, but I just took mine off after having lifted the cab clear of the frame. Half of the 6 bolts broke off by just by wrenching on it - to give you an idea of the level of rust I'm dealing with. Not the worst I've seen, but significant.
Anyway, after lifting the cab free, I tried beating and prying from every direction. The shop manual is comically unhelpful, and I didn't see the home-made puller method.
...so I gave up and cut those suckers out from the top. I basically separated the flat part of the upper metal piece from the sleeve that goes down inside the rubber. The bottom just fell out at that point. Let me know if you want pics.
I need to fab up some new sleeves and top and bottom plates now for the energy suspension bushings I have, but that shouldn't be bad.
Old Sep 24, 2014 | 04:41 AM
Diesel_Brad
That thread has been on the 1st page page for about a week now
Old Sep 25, 2014 | 07:45 PM
LeoJr's Avatar
LeoJr
My truck is virtually rust free, but the very front bolts at the radiator support were rusted about a third of the way at places. The design makes a cup that holds water around the bolt. These bolts didn't snap as the threads were that rust free.
I suggest having front bolts in hand or at least located if you have much rust on your truck already.
Good luck!
Old Sep 30, 2014 | 02:50 PM
1994F2507.3L
well ive made it through the first three cab bushings, took about an hour, i haven't done the drivers side rear yet (the one with the fuel tank in the way) i used the big floor jack with the chain and the bolt method. two of the bolts are ruined, so ill be making a trip to fastenal after this class is over. Also, the drivers side retainer and top sleeve were a little damaged (both front and rear) im going to try and just flatten them back out. I'm not sure how the damage happened but i do have to believe that this truck may have been in an accident at one point or another.
I called ford to try and get bolts and retainers. the front bolt is discontinued. the retainers are discontinued. and the rear bolts are on indefinite backorder. just a heads up for anyone who thought about trying to get those parts from ford.
Old Sep 30, 2014 | 08:17 PM
LeoJr's Avatar
LeoJr
Let us know if the driver side front tank being in the way is an issue. I may be able to give you a few shortcuts.
Old Oct 1, 2014 | 05:38 AM
1994F2507.3L
I'm all ears for some shortcuts. I'd rather not move that fuel tank if I could get away with it.
