Brakes Help!!
Old Sep 21, 2014 | 12:06 PM
Joshua Torres's Avatar
Joshua Torres
Brakes Help!!
While sitting at a light my brake pedal went to the floor slowly. In order to keep from hitting the car in front i pressed the E brake. Bled back , and passenger lines, but couldn't break free driver side, so in fear of breaking it I let it go. No air in lines I checked. If there is air in driver front break line, could it cause break issues?.
Old Sep 21, 2014 | 02:01 PM
fordblimp's Avatar
fordblimp
was the fluid low? If there are no external leaks it is usually a master cylinder leaking internally. Id replace the master and bleed it,you may have to replace other parts if the bleeders wont move.
Old Sep 22, 2014 | 07:54 PM
Joshua Torres
Thanks for responding. No leaks, I'll try that. thanks.
Old Sep 23, 2014 | 03:48 PM
1Aauto's Avatar
1Aauto
Former Vendor
Welcome to the site.
Tony
ddrumman2004
Aug 6, 2005 06:56 PM
new_driver
Jun 10, 2001 08:09 AM
