Pass. side extended cab
Old Sep 21, 2014 | 11:39 AM
RobertJohn's Avatar
RobertJohn
I don't know if my sign. will show my veh.. I've got a 1999 Superduty 7.3 4x4 extended cab.
My son borrowed my truck yesterday and today when he brought it back the passenger side rear extended door won't open. The handle pulls etc. but the door will not open and we've pushed pulled etc. but it's still shut.
From trying to open it I believe it's the top that's stuck or hung.
Is there a way to get this open ? I've thought about taking the handle part open just to see what's there. I noticed also there's a gray plastic cover inside the cab where the closing thing is. Is that a possible way ?
Any and all help will be appreciated.
Thanks
Old Sep 21, 2014 | 03:03 PM
hydro man 17's Avatar
hydro man 17
I believe that the latches are connected via cables. Could be that the upper one broke or came disconnected.
Old Sep 21, 2014 | 03:17 PM
trike1946's Avatar
trike1946
I would open it up and look for anything disconnected. I don't know if there is a way to unhook the latch from the inside somehow. Maybe look at the other side. Can you slide a piece of thin metal from the inside to depress the latch?
Old Sep 21, 2014 | 03:40 PM
AllaboutMPG's Avatar
AllaboutMPG
Found this
https://www.ford-trucks.com/forums/8...oors-wont.html
and this
hope it helps
Old Sep 21, 2014 | 04:21 PM
RobertJohn's Avatar
RobertJohn
I just wonder what the cost would be to have this checked and replaced if necessary ?
Would it be a body shop or what ?
Old Sep 21, 2014 | 10:07 PM
bigtexan99's Avatar
bigtexan99
[QUOTE=RobertJohn;14682322]
My son borrowed my truck yesterday and today when he brought it back the passenger side rear extended door won't open./QUOTE]
Here is my troubleshooting fix it guide for this issue.
https://www.ford-trucks.com/forums/1...ch-broken.html
Please don't blame your son....those plastic pieces that hold the cables in place are brittle and dry...they crack and fail for no reason. Why if I did not know better...I'd say that some engineer at Ford built them that way so they would eventually fail and generate some revenue for a dealership.
Old Sep 22, 2014 | 11:16 AM
RobertJohn's Avatar
RobertJohn
Thanks to everyone for your help.
And bigtexan thanks for the link in the video.
I've got one question.
Do you have to remove the opening handle in the pillar, it's the one you see when you open the front door ?
Old Sep 22, 2014 | 07:15 PM
bigtexan99's Avatar
bigtexan99
No, I don't recall having to remove the read door open handle....the one you see when you open the front door.
One thing that is helpful is if your other rear door is still working, remove the panels, peel back the plastic and use a flashlight to see how the cables operate.
Once you see it, it makes so much sense and its really hard to describe otherwise.
The top latch is the easier one to fix....its really just a matter of positioning the cable in the right place and then using zip ties to secure it in that position.
cabloom300
Apr 10, 2017 11:51 AM
blacklab1
Oct 1, 2015 07:20 PM
diggerdog
2009 - 2014 F150
Apr 21, 2015 08:44 AM
