2010 f 150 extended cab
back doors locked shut
It has been cold but has warmed up over the past few days.
It seems its only the bottom latches that are not working but I find it odd that both doors failed at the same time.
I guess my next move is to remove the panels and check out the cables and the plastic clips that attach to the latch mechanism ???
So, I finally got around to fixing this. I ordered the ends figuring that the plastic broke. After spending way too much trying to get the door apart in the closed position, I found that the ends were fine. Upon closer inspection, the cable to the lower latch had popped off the handle. After putting the cable end back into the slot on the door handle, the door now opens normally. I looked around, but I did not see anything broke. It is strange that happened, but I am happy that my door is now working.
lafermedavid
05-22-2016 08:27 PM
