95 axles into a 91
09-20-2014, 12:43 PM
95 axles into a 91
Will the rear end and front end from a 95 f-250 4x4 with a power stroke bolt right into a 91 f-250 4x4 with a 351W
09-20-2014, 12:59 PM
Quote:
Originally Posted by
Plowboy34
Yes. both sterling 10.25s in the rear.
For the front they are both TTB. But you did not say if the 91 was a super cab or not
95 has Dana 50 TTB
91 will have a Dana 44 TTB if reg cab, D50 TTB if super cab
09-20-2014, 01:44 PM
91 is regular cab...does this pose a problem or is it just an upgrade
09-20-2014, 05:05 PM
It would be an "upgrade" so to speak. But not really worth the effort to swap one TTB with another
09-20-2014, 05:20 PM
Reason for wanting to swap is I now have 3:55 gears and the 95 has 3:73's was hoping would be easy swap as I do want 3:73 gears and can get them cheap
09-21-2014, 09:17 AM
Plowboy34
Unless someone did a gear swap, the 95 has 4.10 or 3.55. They are the ONLY two gear ratio options in those years.
Also swapping from 3.55 to 3.73 would hardly be noticeable. As in less than 150 RPM change unnoticeable
MadMatt65
02-24-2014 03:32 PM
ChappyWagner
01-12-2011 05:16 PM
Jarma36
02-01-2008 10:44 AM
clean79150
07-05-2004 03:50 PM
1977FordF-150
07-06-2003 04:15 PM
